RCU Forums - View Single Post - Need advice on how to correct a sheeting problem...
Old 04-07-2006 | 09:08 AM
RVM
Default RE: Need advice on how to correct a sheeting problem...
Hmm really? I've got a 21st Century sealing iron. I wonder if it'll get hot enough through the sheeting.
Have you ever done this?
Thanks for the tip!
ORIGINAL: Deadeye
Before you go hacking it up, try a very hot monokote iron on the raised part. You might get lucky with the heat melting the Titebond, and allowing the sheeting to lay flat.
