RE: E-FLIGHT BLADE CP
RamboSmurf.... check the pitch on your blades, I had the same problem until I found that I had about 4 degrees pitch on low throttle and low trim, you just might have this problem. besides if you fly like this your main motor will heat up a lot.
Guys... in my field there's always wind running, and sometimes very gusty, normally it is calmed but with wind I haven't been able to foward fly like I want, I start hovering and have to fight it a lot, then I thing it's going to fix when I start going forward and yes it does but 20' later, the tail starts going kind of crazy. I went to a gym and flew for a while, no problems there so I guess this little thing is affected by wind uhh?? First I thought it was my gyro set up but guess not... besides I am kind of new on the hobby... 'been flying planes for about 6 months and heli about 4, I decided what I like is helis so my next target shop is maybe a predator max, I'be been told to buy a Raptor 50 but I rather go with a more stable more capable heli. what do you guys advice??
Thought on going on a bigger electric but I think is very expensive the first buy uhh??
thanks
