RCU Forums - View Single Post - Ultra Stick 60 Balancing problem
Old 12-12-2002 | 11:58 AM
vinnie
Default Ultra Stick 60 Balancing problem
Jeff,
of the two choices opt for the forward CG with less weight. At the very least your chances of a second fight will increase significantly.
As you gain experience you can try different CG/weight combos to get the flight characteristics you want
Good Luck.
