Thanks for the advice! I think I'll try this.
What did you end up having to fix using this method?
ORIGINAL: Deadeye
Yes! Also, this is the desired method of laminate manufacturers. They let the alphetic dry on both the laminate and the substrate, press them together, heat em up, and bingo, instant adhesion.
I have also read on these forums that some guys perfer this method for sheeting built up wings. Apply the glue to both surfaces, and iron the sheeting into place. Give it a try, and keep the iron HOT. Work slowly, especially where the lump is involved. More glue will probably take a little more time to melt. Good luck, and let us know how it turns out.
