t-500 no start
last weekend i flew my new tam f-16 with the t-500 and man what fun till the thing immitated a combine harvesrter. nothing appears to be damaged it spools up ok to around 4800 rpm then nothing happens it spools down with no second spool up the gas pulses when started but no ignition but the box says all is good.
the only thing it shows for a fault is low rpm sensor but the sensor is reading fine
the manual says somthing about ignition low rpm but it only says it about fuel ramping after the start cycle has began
anyone have any ideas outher than sending it back to miami just got it back a couple of weeks ago for new injectors
thanks brian
