RCU Forums - View Single Post - ZDZ 40BS engine problem
Old 04-07-2006 | 06:49 PM
waynem
My Feedback: (58)
Default RE: ZDZ 40BS engine problem
Ragz, I still think you are not getting fuel to the engine on a constant flow. If you have fuel, spark and compression the engine will run. You have not said if you try to rev the engine. If the timing is anything above 0 your engine should idle as long as it gets fuel. Can you try to spray a lite mist of fuel in the carb. while it is running? Hope this helps,Wayne M.
