RCU Forums - View Single Post - Will this setup work well, I'm confused!!!!!!
Old 04-07-2006 | 08:54 PM
Gotta_Fly
Default Will this setup work well, I'm confused!!!!!!
Hey fellows
I left a thread a few days ago and really didn't get the answer I was needing, but maybe you guys can tell me if this combo will work, I have a EP Yak 55 3d, I'm using Hitec 55mg, a Electron 6 RX, a Brushless E-flight park 400 Motor, a Thunder Power Li-poly 1320mAh/11.1v 3cell, and the stock prop which is a 10x4.75,, and my TX is a Futaba 9C,, The problem I'm having is, When you first setup the motor it ask you to give full throttle,and then bring it back then the light goes out, but when I barley move the throttle forward the motor just barley moves then stops and the lights come out,,,, I was wondering I also have a Hitec Micro 555 RX would this one work better, and my last question, when it ask to set your trims back does that mean bring them all the way down, and not centered in the middle....
Randy
