RE: Will this setup work well, I'm confused!!!!!!
Which speedcontrol is it? Also I'd recommend not using the stock propeller that came with the plane. Look at the APC slow flyer propellers. They are a better prop. I've flown that airplane before. It flies very well. Used the same setup except I had a Himax brushless motor on it.
Bevo
