RCU Forums - View Single Post - First Kit Build - Sig Somethin Extra
Old 04-07-2006 | 10:50 PM
  #115
KCRemoteFlyer
Default RE: First Kit Build - Sig Somethin Extra
Hey all, got alot of stuff done this evening, getting really excited to get this done!!!!! I went ahead and bought some 1/16" balsa sheeting and sheeted the turtle deck, learned alot doing that, one side is definitely better then the other, nothing some filler couldn't fix.
A few questions, I bought 2 rolls of monokote (Jet white and Metallic blue), I'll work up a color scheme, but probably going to be blue on bottom, then white on top with some design on both sides. Are there any tips/tricks you have for a newbie coverer? I bought the covering iron as well. Also, is 220 sanding enough or should I do more?
Okay, now for the real newbie question. I've never, ever, set up a glow engive before. The manaul lists how to break in the engine, but it doesnt say to do it on the plane or not. Is it a bad idea to break it in on the plane, outside staked to the ground?
Also, The wife has veto'd getting a prop balancer and CG apparatus (for this build ... I'm way over budget [8D]) So what can I do at home to replicate these? Or is it just a bad idea to try it myself. CG shouldnt be a problem ... can probably make something out of some plywood that would do the job.
Let me know!!
ID:	440762   Click image for larger version
ID:	440763   Click image for larger version
ID:	440764   Click image for larger version
