RCU Forums - View Single Post - t-500 no start
Old 04-08-2006 | 07:34 AM
Jet Lag
My Feedback: (26)
Default RE: t-500 no start
For whats it worth,if you are starting with the ground unit attached to the ECU,try start sequence without the ground unit hooked up.If it spools up and goes to the ramp sequence you have a faulty ground unit harness lead.Also check your routing of the RPM sensor wire away from any other wires.I have also seen this happen when radio transmitter antenna was to close to rpm sensor wire when starting.Good luck.
