RCU Forums - View Single Post - Filling Hinge Gaps
Old 12-16-2002 | 12:23 AM
ptarp
Default STILL a bit confused
TerrellFlyer,
So, when I flex the control surface, do I iron the covering flat across the hinge surface, or do I go down into the hinge gap as in MinnFlyer's pic. Just thinking about it, if I do it flat, the covering will "pucker" out when the surface is neutral or in the direction of the side with the gap covered, is that O.K.(or does that not happen)?
P.S. I'm pretty sure you do, but just to make sure...
Do you 'fill the gap' along the entire surface, or just around the hinges?
Thanks guys!
