RCU Forums - View Single Post - battery question
Old 12-12-2002 | 06:07 PM
Crashem
Default battery question
Also remember that testing the battery pack under load is very important. I believe the meter I have puts a 100mah load on the pack. If yours does not you should get one since the only time they are under a load is when you are using them.
Without a test under load it will be hard to determine if you have a bad cell or a cell going bad.
