RCU Forums - View Single Post - First CL flight..OS 32 venturi
Old 04-08-2006 | 11:50 AM
doucette's Avatar
doucette
Default RE: First CL flight..OS 32 venturi
well, I went ahead and got replacement parts for the old r/c carb, less than twenty dollars including shipping. I pulled the engine and am in the process of beefing up the fusalage/motor mount section to reduce vibration. Not much wood up there on the ARF Flite Streak, I'm sure Ill get a more consistent run with less vibration. Fuel foaming was a bit of a problem on the first day. Thanks all for your input!
Tom
