RE: Will this setup work well, I'm confused!!!!!!
I am guessing here, but it sounds like it wants full throttle when you first turn it on. It then senses that and asks you to set it to full low throttle. If this is the case and it is not working it is probably because you need to reverse the throttle direction on your transmitter.
