ORIGINAL: DiTi
maybe you could try leaning the mix alittle bit by the High Speed Needle. Also check if there is any leak around the exaust area. +it sounds like you need to adjust the idle too(anti-clockwise lowers the idle so clutch does not engage...)
good luck
alright i got the hsn figured out but i dont know where the idle thing is. someone pleas help
