RCU Forums - View Single Post - Help on Infinity Samurai 528 engine
Old 04-08-2006 | 10:42 PM
ryan_t888's Avatar
ryan_t888
Default RE: Help on Infinity Samurai 528 engine
Are you referring to the spray bar? I believe this does not need to be adjusted as it doesn't matter which angle it is at. (open end spray bar)
If the spray bar's hole is offset or at an angle it should be towards the engine crankcase.
Why do you need to adjust it? It may be a permanent setting.
Ryan
