RCU Forums - View Single Post - Bubbles in the fuel line..AGAIN!
Old 04-08-2006 | 10:55 PM
RCKen's Avatar
RCKen
RCU Forum Manager/Admin
My Feedback: (9)
Default RE: Bubbles in the fuel line..AGAIN!
Check to make sure the tank isn't touching the frame before spending the cash on the new clunk. If you have problems with the foam shifting when you slide the tank in you might want to spray a little bit of 3M 77 adhesive on the back of the foam. This will give enough "stick" to secure it to the inside of the plane, but you can still get the foam out later if you need to.
Hope this helps
Ken
