RCU Forums - View Single Post - New engine
Thread: New engine
Old 04-09-2006 | 12:31 AM
  #38
spacewalkerSG's Avatar
spacewalkerSG
My Feedback: (-1)
Default RE: New engine
Yes guys..
What he told you is correct..engine is tested and parts needed to be change will be changed....kudos to you Ralph....i support this...
Even if he has tested and proven the engine..i personally will get the engine that have been QC from him....
ORIGINAL: RCIGN1
Spacewalker..Of course it came from CHINA, like almost everything else these days...
The cylinder appears to be the same as the SPE26, but the case is definitely different...
It's supplied with a rotary barrel carb..That will be changed...The hub is made in the USA from 2024 aluminum, and will not strip easily..If the crank bearings are not good enough they will be changed..There will be NO bell cranks to operate the carbs, the throttle will connect directly to the throttle servo..The crankcase is flat across the back, no mounting plate needed,no spindly legs to break...If testing reveals any other flaws they will be corrected or the engines will not be sold....PERIOD...
They will each be run before shipment, the customer should not be expected to be the tester, there will be no release until everything is RIGHT...
There will be a warranty, engines will be repaired in the USA, all parts will be available......
All this will not happen if the engines turn out to be of poor quality after HARD testing...
