RE: control throw meters: you need them?
I use a throw meter when setting up dual elevator servos to make sure both elev. halves are moving exactly the same distance. As for setting up high and low rate throws I just eyeball it to where it looks close to the recommended then fly and adjust the throws to suit me. The recommended throws are usually very conservative.
