JMP Firebird servo selection help .. ??
I am picking out what servos to use on my JMP Firebird. I’m figuring 8411s o the ailerons, and 2721s on the flaps ( I don’t like digitals on flaps ) … As for the Rudder, will a 8611 fit in there ?? ( manual calls for a servo with the same dimensions of a 8411 which is a bit smaller)
Most importantly, how about the Elevator ? I no longer see the Multiplex Jumbo V2/stab servo specified anywhere in the Multiplex catalog. I did find a plain “jumbo” servo from multiplex on the tower hobbies site, but its rather slow at .33 transit time …. I did also find a triple bearing servo from Multiplex called the :Rhino” which has around 200 oz of torque, and a .12 transit time , and is the same size at the “jumbo” …. What are you guys using on the firebirds ? what are the available / recommended options ??
Voy
