RE: Flight Streak First Flight
zimzimma,
First check that there is no wing warp.
Assuming a straight wing, tape some weight on the outer wing tip to see if it helps.
If it helps, adjust the amount of weight until the wing flys level. THEN, cut into the wing and install the weight permanently.
Good luck.
George
Edit: Afterthought. What diameter lines are you using? Should be .015's.
