RCU Forums - View Single Post - da-50 stutter problem,help please
Old 04-10-2006 | 07:52 AM
JoeAirPort's Avatar
JoeAirPort
My Feedback: (41)
Default RE: da-50 stutter problem,help please
If the low end is set right, it will need to be warm before it will transition (like others have said). That popping could be a rich low end. If it's 4 cycling that would explain it. Lean the low end while the engine is warm until it bogs or hesitates (too lean). Then richen it up from there. I think many of the DA 50 problems is a rich low end, especially if the factory settings are used. Check all throttle positions between idle and 3/4 to make sure it's 2 cycling.
ORIGINAL: discusmike
Well,flew today,did not stutter any during starting,but nevertheless was popping away during flight...
