RE: My next project
I would align the bottom of the wing at zero degrees to the long axis. This will give the wing a bit of positive incidence and in my experience with planes of that type, it should be about right. I would also: Keep the stab at zero, make the engine thrust adjustable or just set it at 3 degrees down or so (since the wing is 8" above the thrust line), and 2 degrees or so right thrust.
