RCU Forums - View Single Post - Help with Futaba Range check
Old 04-10-2006 | 02:17 PM
Kelly W
Default RE: Help with Futaba Range check
Hi John,
Just one thing to try... You don’t make mention of the turbine used here, but some ECU's are not intended to be flown with the Data terminal attached. If that’s the case, try disconnecting after the start is complete it and see what the test result is... I'd try this before changing to a base loaded antenna.
Good luck,
Kelly
