RE: Antenna question
have doubled back the extra 5" of my antenna using a servo arm piece to attach arubber band to then another at the end of the antenna to prevent it from touching it works fine as long as you dont twist the extra it will work fine. if your worried about it then take up the extra slack and hide it in the fuse. personally I would rather the extra be out side of the fuse.
