ORIGINAL: aero nut
Hey Rysium did you ever get to the 4 stroke ryobi???? did you try the gas/glow mix on it???
No, I dumped the idea of using this engine in my Wilga, because it is to big (to high) to fit inside the cowl. I decided to use Poulan 42 instead. The 42 is still in the chainsaw (cutting some tree
) but when I'm ready I will dig it out.
ORIGINAL: aero nut
what ever happened to your weadeater 25 are you still using the gas/glow mix and did you change the duration timing on the exhaust and intake? it sure did a lot of difference on my engine!!!
I wish I have the time. All three 25s are "base" not cut yet. I'm still planing to cut ports in one to see if it helps. I got Seagul Harrier 90 3D last year (still in unopened box[
]) and now I think cut Poulan 25 with glow setup can make this plane fly. It just needs to wait for it's turn. My top priority project is to finish gigant Wilga.
This week I'm in Tampa,FL in business - another weak wasted
