RE: Camera on a BCX-CP, is it possible?
That 9v there probably is the heaviest part of the setup. Since the heli already carries a battery, might as well use that. Just build (or have someone build) a circuit that regulates the voltage from the main pack to 9v to a 9v plug and you are set. Or make it go straight to (what looks like) the mono plug, eliminating a little extra wire and connector weight.
