RE: Quique Somenzini YAK-54S 73"
Thanks for the detailed notes.. I will consider, but, I'm not sure i'm comfortable cutting back the fire wall although it does appear to be a simple procedure. I may be able to loose that inch using the provided mount. I will check the carb. clearance... I do have a well broken in Saito 180 as well...:0)
