RE: SKYSHARK CHRISTEN EAGLE ANYONE BUILT THIS MODEL?
Make sure that the engine has 2 degrees of down thrust and the top wing incidence is set at +1 degree from the bottom wing. If it climbs when you add power, you need to either add more incidence to the top wing or more downthrust to the engine until it flies level at all throttle settings.
Mike Grey
Skyshark R/C
