RE: metal in oil
how would I adjust differential with only one aileron servo though? It does have a differential problem as it yaws badly if you pull an upline and do a roll. I could drill out a round servo wheel with the holes behind the output shaft, wouldn't that change the differential? If I am visualizing correctly that would take it out. The ailerons go down more than up.
