RCU Forums - View Single Post - Hangar 9 P51 inverted engine keeps stopping
Old 04-11-2006 | 02:17 PM
Stickbuilder's Avatar
Stickbuilder
Default RE: Hangar 9 P51 inverted engine keeps stopping
CH, You ain't listning. I need a tank that will fit between the firewall and the first former in the H-9 P-47 (.60 size) otherwise, I am going to have to cut a tunnel in the top of the wing at the center in order to get my tank C/L closer to the carb height. I can do this without comprimising the wing mount, but I druther not. Surely someone has a tank that is shorter (front to back) and wider that will fit in the needed space. My carb is 3/4" lower than the tank centerline, and the fuel siphons out when the engine is shut down.
Bill
