RCU Forums - View Single Post - FALCON III COMPLETION
Old 04-11-2006 | 04:42 PM
RCKen's Avatar
RCKen
RCU Forum Manager/Admin
My Feedback: (9)
Default RE: FALCON III COMPLETION
ORIGINAL: bruce88123
ORIGINAL: RCKen
To be totally honest with you you should be just fine making a bracket and gluing to the stock ribs.
Are the ribs in this plane comletely solid with no lightening holes in them at all? There is no way to run a wire through the ribs right now??
Ken
If you look at post #1 you will see that there are no holes in the ribs. You are probably right about not needing to reinforce the ribs as Goldberg built them tough/strong.
Guess that will teach me to skim over a post like this then!!
Use a drill with a 1/4" bit in and drill at an angle into each rib, drill the same spot on each rib, and drill a hole for your servo wire.
Ken
