RE: PCM vs FM
well to me it depend on weather everyone else at thefeild uses it. if your on PCM and some else is on fm on the same channel it won't effect your model. you'll effect him though. Glitch wise i thinks it's perception. that advantage is PCM has a fail safe that when set right will upon signal loss reduce engine to idle.
