RCU Forums - View Single Post - engine compression
Old 04-11-2006 | 08:52 PM
martinanderson
Default RE: engine compression
thanks i figured that it runs pretty hard but seems to want to cut out full throttle and it dies if i lean it out and dies if i richen it up, so i figured i will live with it until the engine is shot since it is the one needle wonder which you already know that we chated about it before, it is fine at about idle to 3/4 throttle (it runs good enought to break, rear a-arm, shock tower and bend shock, front door mount and make the engine gear wear very good just waiting for the trans gears to strip[>:]I wish they would make em better) but anyways thanks i'm not going to worry about it then.
martin
