RCU Forums - View Single Post - Review of the Wild Hare CAP 232
Old 04-12-2006 | 12:14 AM
  #55
ben beyer's Avatar
ben beyer
My Feedback: (23)
Default RE: Review of the Wild Hare CAP 232
So I finally got a chance to work on the CAP. I started tonight by installing the SIG wheel pant mounts. If you've never used them, I suggest you try them. I first figured out where the inside pant needed to go. Then, using the axle, I found where the outside pant goes. I just used the drilled holes for the inside pant to figure out the drill location for the outside mount. I used a GP dead drill tool to accomplish this. Just took it out of the rest of the tool. Once you do one side, do the other.
ID:	443832   Click image for larger version
ID:	443833   Click image for larger version
ID:	443834   Click image for larger version
ID:	443835   Click image for larger version
