RCU Forums - View Single Post - Flight Streak First Flight
Old 04-12-2006 | 07:19 AM
gcb
Default RE: Flight Streak First Flight
If you can, try a set of .015x60' lines. Yours were probably marked as .018 which is for larger engine/plane combinations. Symptoms of too heavy lines are inboard wing lower and excessive bow in lines when plane is flying...both of which can lead to less line tension, etc.
George
