RE: unusual diff problem, can you solve????????????????????????
When you mounted the engine did you use a piece of paper in between the spur gear and clutch gear? One of my buddies had his too tight and it caused him some problems. also, make sure your engine and spur gear form a 90 degree angle. If its off a little bit I can see that causing the problem too.
