RCU Forums - View Single Post - FALCON III COMPLETION
Old 04-12-2006 | 01:25 PM
shd3920
Default RE: FALCON III COMPLETION
Sorry for the quality of the pic, it was a library book and did not explain how to do it.
I looked at the figures again and decided it would be simpler for a beginner like me to just buy the other servo. So will do, I will find the funds.
I temporarily screwed the servos in place in the fuselage to set all that up and install the pushrod tubes. It was only a setup procedure so I did not put the grommets or brass fittings in place on the servos, not a permanent installation. I turned the TX on to test the rudder rod installation and the servos went absolutely nuts (very noisy and moving spasmodically). Please tell me that is happening because I do not have the grommets and brass fittings in place on the servos and it is being caused by heavy vibrations and will be fixed after putting in the grommets to cushion the servos. I am using the same TX as I am for the LT-40 and YES, the LT-40 is off when I am doing this.
