RCU Forums - View Single Post - Blade CP - Throttle touchy, is that normal?
Old 04-12-2006 | 02:14 PM
wilburwreckage
Default RE: Blade CP - Throttle touchy, is that normal?
If you have a Hitec with spectra module, you just dial in the frequency of the OEM crystal.
On the stock TX one thing to try is upping the throttle trim. At higher head speeds you may find it easier to manage altitude control.
HTH
Si
