RE: Servo Buzzing
Marc;
You have been great help, you seem to know this stuff pretty good where I need some help; the setting the servo arms at zero with doors closed makes all the sence in the world; but what about keeping the doors open as is the case on a P-47 when the gear is down; there is no load on the open doors other than keeping them open; would this be a big drain on the battery, although when the plane is parked you have the battery turned off, I would think the only drain would be when you turned it on to fly and doors would stay open till a point when you retract the gear upon being airborne?
Doug.
