RCU Forums - View Single Post - Down thrust on a trainer is it a good thing?
Old 04-12-2006 | 04:49 PM
rmh's Avatar
rmh
Default RE: Down thrust on a trainer is it a good thing?
upthrust on a Giles?
sounds like an underpowered setup or the measuring stick is off.
The only time we found low wing-high thrustline setups to need up thrust -- was on models which lost speed on uplines
lose of speed = need for upthrust
same situation as as in level flight .
when we wre testing this -it was on a TOC design - increasing thrust (more power)-solved the problem
If speed remains the same -- trim remains the same - made sense to me
what do ya think?
