RCU Forums - View Single Post - What clear coat
Old 04-12-2006 | 07:50 PM
Campy's Avatar
Campy
Default RE: What clear coat
I have been using Rustoleum for my base colors. I have a water based spar urethane that I was thinking of using to clear with. Will one coat be enough? I have a sprayer and have sprayed some test areas. It seemed to cover pretty well when applied somewhat wet. Or would you think I should apply in several built up coats.
_____________________________
Brian
Brian,
I use 2 medium sprayed coats of Minwax Polycrylic. I let the first coat dry at least an hour, then do the 2nd coat.
