Zero side or right side thrust
Rajul,
the reason for right thrust is to counter the effect of prop torque pulling the aircraft left on the ground. A nose gear tends to lessen that effect somewhat. A taildragger's ground handling benefits significantly with a couple of degrees right thrust. But as I said, a degree or two won't hurt in either case with the airplane in question.
