Zero side or right side thrust
You also need right thrust to keep the plane from veering to the left when going vertical. That's a good way to see if you have enough. As for downthrust with a pattern plane and everything else being right down thrust will make it fly level inverted. To little down thrust and you will have to feed in some elavator
