Zero side or right side thrust
P factor is cause by the angle of attack on the blades of a prop.In level flight the ascending and descending blades have equal angles of attack,producing uniform lift. As the plane enters a climb,the descending meets the air at a greater angle of attack than the ascending blade and as a result produces more thrust.This increase in thrust produces a left turning tendency,which can be countered by right rudder,engine side thrust or a combination of both.
