RCU Forums - View Single Post - Zero side or right side thrust
Old 12-20-2002 | 01:57 AM
TerrellFlyer
Default Zero side or right side thrust
Rajul you are testing my small mind now,but here goes.When going to a negative-G maneuver,the force is applied to the top of the prop as it spins,causing the effect to be felt on the right side and can be countered the same as P- factor.This is called the gyroscopic precession.All of this is if the prop is spinning to the right,if spinning left then the corrective action will be opposite.
