RCU Forums - View Single Post - My next project
Old 04-13-2006 | 10:28 AM
Jim Thomerson
Default RE: My next project
I don't see what the problem is putting dihedral in. All you have to do is put the wing tube fitting in the tip part at an angle rather than flat. Instead of an I beam, I would build a box spar with about the same amount of material, and taper the amount of material from the center section out. I would build up the ribs with the curved top laminated. I'd end up spending many happy hours over complicating things.
