RE: Welcome to Club SAITO !
Vibration Question on the 1.25 Several of us on the kit building are building Ultimates from CG, I've reinforced the fire wall and used larger bass stringers than the balsa stringers. I put a bead of silicone under the servo tray. Do you think I need a soft mount for the engine. Everything is packed in foam except the servos and the switch (which is an MPI heavy duty). Have any of you guys actually experienced problems from vibration.
