RE: Hammer servo reversing?
Hi
You shouldn't need to reverse the switch on the controller. Just push the trigger forward to reverse the motor.
You aren't in a whole lot of danger with a plastic prop and so low power motor. Now if you had a good sharp metal prop and more power then, you really need to look out. n.h.schmidt
