RE: RC Flight Sim form Clear View
The speed should not change for the demo or purchased version.
What do you mean "Choppy"? Was the screen not refreshing fast enough (makes it look like a strobe effect)?
What kind of computer system do you have?
You can also try this...
Go back into the properties for your monitor.
In windows XP:
- right click on the desktop, you should get a pop-up menu with one of the choices as Properties
- go to the Settings Tab
- click on Advanced button
- change the refresh rate as high as it will go (usually about 75 Hz)
- this should remove some of the flicker.
If this doesn't work, let me know...
Terry
